mSGDMA: Streaming to MM problem
Hi everyone,
Recently, I want to play with mSGDMA and learn about it so just make up my own project to test and see the behaviour and know how to control the mSGDMA. However, I got stuck and have tried everything I know but still cannot fix it.
HARDWARE:
-HPS with h2f_lw_bridge
-mSGDMA:
- Streaming to Memory Mapped
- Data width: 8
- Data Path FIFO depth: 32
- Descriptor FIFO depth: 32
- Maximum transfer length: 1KB
- Transfer type: Aligned Accesses
- Everything else is disabled
-My customized counter with streaming interface: I made this component just to test the mSGDMA. The counter increase the value every 1 second and output it in streaming interface. It has:
- Data width: 8 bits
- Data bits per symbol: 8 bits
-LED PIO: written by mSGDMA write master with the transfered data and it is supposed to increase every second.
SOFTWARE:
Here is C code:
typedef struct sgdma_descr
uint32_t *read_addr;
uint32_t *write_addr;
uint32_t length;
uint32_t control;
}sgdma_descr_t;
int main ()
uint32_t status ;
/*bridge configuration*/
alt_bridge_init(ALT_BRIDGE_LWH2F,NULL,NULL);
alt_bridge_init(ALT_BRIDGE_H2F,NULL,NULL);
sgdma_descr_t descr;
sgdma_descr_t *descr_ptr = &descr;
// configure the descriptor for ST to MM transferring
descr->read_addr = NULL;
descr->write_addr = 0; // address of PIO seen by mSGDMA write master
descr->length = 1;
descr->control =(1<<31) ; // no setting, just go for one data transfer
// feed the descriptor to the descriptor slave
alt_write_word(DESCR_RADDR,descr->read_addr);
alt_write_word(DESCR_WADDR,descr->write_addr);
alt_write_word(DESCR_LENGTH,descr->length);
alt_write_word(DESCR_CONTROL,descr->control);
uint32_t status;
while(1)
// observe value inside the registers
status = alt_read_word(CSR_STATUS);
printf("Status: %u\n",status);
status = alt_read_word(CSR_CONTROL);
printf("CONTROL: %u\n",status);
status = alt_read_word(CSR_LEVEL);
printf("LEVEL: %u\n",status);
return 0;
}It states that the mSGDMA is still busy transfering ( Busy bit is set ) and the descriptor buffer is empty ( Descriptor buffer empty bit is set and the value in Write fill level register is 0 ). However, I see nothing is transferred because the LEDs are not lighted up.
I had tried the same test with regular DMA Controller and it worked fine. But with mSGDMA it does not work with my test.
Hope someone can give me a hint how to fix this. Thanks in advance !
Cheers!
- GuaBin_N_Intel
Contributor
Your command sequence seems good to initiate a DMA transfer. Can you confirm whether streaming data is written correctly into the SGDMA? You may use SignalTap or simulation to check it.
- DChau5
Hi GNg,
Thanks for your response!
I also doubt that my streaming interface is a problem because I work fine with MM-MM. I did check it my streaming interface with Modelsim and also implemented it with Avalon FIFO, it works fine.
Maybe I will test it with SignalTap but I need to learn how to use because I have never used it before 😅 .
One thing also got my attention. At first, my counter's data width is 32 bits and data bits per symbol = 32. I got a warning that the mSGDMA data bits per symbol is only 8, if I want to transfer 32 bits data, I have to configure it to 8 bits data per symbol and 4 symbol per beat. I do not know how to change it to 4 symbol per beat. Whenever I change to 8 data bits per symbol ( with data width is 32 ) in "New Component" configuration window, it only transfer my 8 LSB data[7:0].
Once again, thanks for your answer. I will check on SignalTap when I have time.
- GuaBin_N_Intel
Contributor
It is pretty straightforward for SignalTap usage. Go through this training https://www.youtube.com/watch?v=DCUhsezqydQ would help. Which interface do you need to change its bits per symbol? source streaming from counter? Refer to avalon-mm spec https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf, Table 18,pg43, you are able to change its streaming properties using "dataBitsPerSymbol"
- AKb
I am trying to implement triple speed ethernet in Cyclone 10 FPGA. I have integrated triple speed ethernet core in platform designer in qsys. If i pump data and do loop back in system side of MAC, its working fine. I am able to monitor Start of packet, data valid, data, End of packet properly in signal tap. Now my aim is that i try to capture the streaming data in system side of MAC directly in Nios side memory. For this i am using Modular Scatter gather DMA. For receive data i am using one MSGDMA in streaming to memory mode and one for transmit data i am using one MSGDMA in memory to streaming mode. I try to capture data in descriptor memory in onchip ram. But i am not getting any data.
I have doubt about my connections of MSGDMA in Qsys.There are no any specific examples detailing how to use MSGDMA with TSE. Some people have done it with SGDMA . I am using quartus 18.1. So how to go about it. How to capture data in onchip RAM.
Kindly guide
Av
