16 years agoMSB not used in FFT Megacore Function
I am currently using the FFT MegaCore and I remarked something strange about the output resolution. I tested the function in Matlab using the model with different types of signals (sine, noise,...
16 years agoInteresting...
I noted the same thing in altera's first releaeses (back in 2001) and raised the issue to them. The following fft version improved . You might set the bitwidth higher to force it to use more bits if indeed it is not enough.
