14 years agoMPFE integrated in DDR3 Controller with UniPHY
In the new Quartus 11.1 QSYS, I am happy to see that the Multiple Port Front End (MPFE) is included in the UniPHY DDR3 SDRAM Controller IP. However, I don't understand how to configure it.
See the attached picture, I have marked the MPFE section inside a red line. The MPFE section is not clickable and nothing appears in it. The section is not documented. How do I configure the MPFE inside the UniPHY DDR3 SDRAM controller IP? Regards, Steffen3 Replies
i can't figure it out either
This multi port is not the same as the soft MPFE, and the option is only available for the hard memory controller on Arria V and Cyclone V.
ah i see, you have to check the Hard Memory IP at the top of the UniPHY wizard
thanks
