11 years ago
Modular SGDMA - Streaming to Memory Mapped Random first write.
I am using the Modular SGDMA to write memory into DDR3 memory, and then a second one to read it back out again. The reading is all working fine and writing into the memory works as well, except there is one minor glitch.
Basically when I issue a descriptor to write a given number of symbols to, say, address 0 (the burst length is 16 and I'm using a 512bit wide data bus).
Then, Symbol 0 arrives via Avalon-ST. It immediately gets written by the SGDMA to address 0xFFFFFFFF.
The next arrives and it gets queued up in the FIFO. Once symbol 16 arrives, there is a burst write of 16 symbols to address 0x0.
Essentially this means the first symbol to arrive for any descriptor appears to get written to 0xFFFFFFFF, and then the remaining symbols get written to memory one address earlier than they should, thus the first symbol is lost and the rest are shifted from where they should be.
Any thoughts on why this is happenning?
EDIT:
I'm using a Stratix V DSP board and Quartus 14 Subscription Edition, have SignalTap set up to look at important parts of the SGDMA controller and data input. Also the design meets timing comfortably.
    TCWORLD,
    Can you provide some of the C code you used to control the dispatcher. I am trying to save streaming data to SDRAM on the De0-Nano board, but even though I can write in the descriptors, the dispatcher doesn't execute them. So I'm wondering what is wrong.. I followed the same code procedure seen in the Modular SGDMA demo on alterawiki. Are you using the standard or extended dispatcher, i've tried both but neither worked for me. not sure where the error is.
    My qsys set up is as follows:
    Transfer mode: streaming to memory
    Descriptor fifo: 32
    Data width: 32
    Length width: 20
    FIFO depth: 64
    Burst Enable: on
    Maximum Burst Count: 16
    Force Burst Alignment: on
    Full Word Access Only
    I had all sorts of fun trying to get those controllers to work. I ended up writing my own Avalon-MM width adapter for the dispatcher, it seems the Qsys generated interconnect was causing all sorts of problems (maybe a glitch in Qsys?). That got it to sort of work, but in the end I just ditched them as they were proving quite flaky - sometimes working, but then locking up for some unknown reason. (I've been slowly ditching most of the Altera IP cores from my designs as they seem to be more trouble than they are worth).
    In the end I wrote my own DMA controller, which to be honest I should have done in the first place, I was just being lazy at the time.
    That is sort of what I expected... All though this is bad news for me since I'm pretty beginner with Verilog. Do you have any guides or tips on how to write a DMA controller?
    I've attached the Nios code I was using.
    In your main c file,# include "ScatterGatherController.h", then declare a global variable as:
    PSGC_CONTROLREGS const dma_csr_base = (PSGC_CONTROLREGS)(<Base address of the CSR, e.g. from system.h>)
    PSGC_DESCRIPTOR_FORMAT const dma_descriptor_base = (PSGC_DESCRIPTOR_FORMAT)(<Base address of the descriptors, e.g. from system.h>)
    You can then pass those pointers to the functions in the .h/.c files as the 'base' variable.
    You'll need to initialise the controller. This can be done using sgc_initialiser(), sgc_enabler(), and sgc_enableDispatcher(). See the .h file for the function declarations.
    If you want to send a descriptor, you can create the following:
    SGC_DESCRIPTOR_FORMAT descriptor;
    descriptor.write_address = ...;
    descriptor.read_address = ...;
    descriptor.transfer_length = ...;
    descriptor.control.bits.<some field, see .h> = ...;
    sgc_issue_descriptor(dma_descriptor_base, &descriptor)
    Hope the SGDMA controller proves more reliable for you than it did for me.
    Thank you! I'll let you know if it works in my application.
    TCWORLD,
    So I was able to implement your code, however I still get the same result: The DMA descriptor FIFO fills up and then stays filled - so no descriptors are actually being executed.
    Let me outline my system (maybe I'm making a fundamental error):
    The goal is to transfer streaming data into the SDRAM chip on the DE0 Nano board. I want the code (.text,.heap,.stack, all of it) and the descriptors to be held in on - chip memory, while the streaming data is saved on sdram.
    Therefore, in my linker script in the BSP setup, everything is set to onchip memory.
    In qsys, the data_write_master from the dma_write_master module is connected to the s1 port on SDRAM. The nios data and instruction masters are connected to onchip memory, and the data master is also connected to sdram s1 port for a way to read data for testing purposes.
    So essentially, code and descriptors are on onchip memory, data should be saved to sdram via msgmda.
    For some reason, when I used the C functions provided with the msgdma and when I used you ScatterGatherController files, I got the same result of the descriptor FIFO filling up, but no data actually being saved.
    My data (for testing purposes) is currently a counter that increments every N number of clock cycles (N = 1000). So the data rate is 50MHz (base clock) / 1000 = 50kHz. Every N clock cycles a valid signal is triggered.
    I can't find an issue, I've tried various combinations of burst vs. non bust, full word vs. aligned options, etc. No change in results. Let me know, if I'm missing something really obvious, or if you think of some reason that can be causing this issue. It would help a lot.
    Thanks!!
    As I said, I gave up on the Altera IP Core. It seems far too glitchy and unstable to be used in any serious system. Better off finding a different one, or writing your own.
    Good news TCWORLD. Seems I was able to fix this dispatcher issue. Apparently I had a typo in some of my custom verilog code I wrote, and it was preventing data from being sent to the sgdma. Therefore the descriptors weren't executed since the stream data was never valid. I've only done some preliminary tests so far....
    My next operation would be to set up a MM - MM sgdma to transmit the data in SDRAM to external flash. Any suggestions on an open core flash memory controller (SPI not CFI)?
    Also I'm concerned with writing and reading to SDRAM - this may cause collisions and/or corruption of data, but I will have to see what happens.
    Thanks for the ScatterGatherController code.
    Hello, guys. I"m also trying to use mSGDMA IP.
    So I have a question regarding data length.
    Did you try to use data length not multiple of data bus width?
    My configuration is as follows
    Transfer mode: MM->ST
    Data width: 32
    DAta FIFO depth: 256
    Descriptor fifo: 128
    Maximum Transfer Length: 1 KB
    Length width: 20
    Transfer Type: Unaligned access
    Burst Enable: on
    Maximum Burst Count: 64
    Force Burst Alignment: off
    Packet Enable: On
    Channel Enable: On, 4
    Error Enable: On, 8
    From what I see in simulations:
    If I set Descriptor as follows:
    Start addr: whatever (let's take 0x0)
    Length : 51 ( any not multiple of 4 bytes)
    Flags: Go,SOP,ErrDonEn,Channel,Error,!EOP
    So msgdma initiates two transfers:
    1. Read burst request for 12 * 4 bytes
    2. Read request for the last data for 3 bytes
    But in the result on ST interface
    we get 52 bytes without any notice that the last byte is invalid (cause no EoP thus no empty signal)
    So does anyone knows method of transferring not multiple of bus width bytes via MM->ST interface?
