missing .ipx file in 18.1 quartus
@JohnT_Intel
Error: Missing file C:/intelfpga_pro/18.1/nios2eds/hw_library.iipx
Error: Missing file C:/intelfpga_pro/18.1/nios2eds/sw_library.iipx
Error: Missing file C:/intelfpga_pro/18.1/quartus/sopc_builder/hw_builtin.iipx
Error: Missing file C:/intelfpga_pro/18.1/quartus/sopc_builder/sw_builtin.iipx
- SyafieqS
Hi Ashwi,
More information needed here on how did you encounter such error?
- SyafieqS
Hi Ashwi,
Verify the .ipx file is there in the directory and try to check you environment variable if they are added for both quartus and nios2eds.
- APPU_appu
@SyafieqS @Deshi_Intel @JohnT_Intel
I checked in folder .ipx is found, enviranomnet also path added but again we are facing same issue. can you please address this issue
- Meisam
May I ask if this problem has been resolved for you? I encountered the same issue while working with Platform Designer.
