APPU_appu
5 years agomissing .ipx file in 18.1 quartus
@JohnT_Intel Error: Missing file C:/intelfpga_pro/18.1/nios2eds/hw_library.iipx Error: Missing file C:/intelfpga_pro/18.1/nios2eds/sw_library.iipx Error: Missing file C:/intelfpga_pro/18.1/quar...
SyafieqS
5 years agoHi Ashwi,
Verify the .ipx file is there in the directory and try to check you environment variable if they are added for both quartus and nios2eds.
APPU_appu
5 years ago@SyafieqS @Deshi_Intel @JohnT_Intel
I checked in folder .ipx is found, enviranomnet also path added but again we are facing same issue. can you please address this issue
- Meisam2 years ago
May I ask if this problem has been resolved for you? I encountered the same issue while working with Platform Designer.
