TKapi's avatar
TKapi
7 years ago
MAX 10 Erasing via On-Chip Flash Intel FPGA IP - SOLVED
Dear friends,
I'm using MAX10 (10M08DAF484C8GES), Quartus 18.1 and On-Chip Flash Intel FPGA IP.
My problem is:
When I need erase Sector ID1 or ID2 (or another), the "busy" from Core status Register goes to High (2'b01 BUSY_ERASE) and next clock goes to Low (2'b00 IDLE). But the "es (erase successful)" is Low (1'b0 Erase failed). What can i do?
wp (Sector ID x write protection) is disable, sp (Sector ID 1 protection bit) is Low to (I can't setup, but I read 0).
It's normaly, when "busy" goes High (BUSY_ERASE) and next clock goes Low (IDDLE)?
My simplified code:
erase_state: process(PIN_OSCILATOR)
	begin
		if(rising_edge(PIN_OSCILATOR)) then
			if(flagErase='1') then
				actionErase<='1';
			end if;
			case stateErase is
				when ERASE_READSTATUS_A_ON		=>
					flashConfigAddr<='0';	--Status register
					flashConfigRead<='1';
					stateErase<=ERASE_READSTATUS_A_OFF;
				when ERASE_READSTATUS_A_OFF	=>
					flashConfigRead<='0';
					stateErase<=ERASE_READSTATUS_A_VALUE;
				when ERASE_READSTATUS_A_VALUE	=>
					flashStatus<=flashConfigReadData(9 downto 0);
					stateErase<=ERASE_DISABLEWP_ON;
				when ERASE_DISABLEWP_ON			=>
					if(flashStatus(1 downto 0)="00") then		--Idle
						flashConfigAddr<='1';	--Control register
						flashConfigWrite<='1';
						flashConfigWritedata<="11111110011111111111111111111111"; --Disable write protected mode Sector ID1, ID2
						stateErase<=ERASE_DISABLEWP_OFF;
					else
						stateErase<=ERASE_READSTATUS_A_ON;	--busy, testing again
					end if;
				when ERASE_DISABLEWP_OFF		=>
					flashConfigWrite<='0';
					stateErase<=ERASE_READSTATUS_B_ON;
				when ERASE_READSTATUS_B_ON		=>
					stateErase<=ERASE_READSTATUS_B_OFF;
				when ERASE_READSTATUS_B_OFF	=>
					stateErase<=ERASE_READSTATUS_B_VALUE;
				when ERASE_READSTATUS_B_VALUE	=>
					stateErase<=ERASE_ERASECFM2_ON;
				when ERASE_ERASECFM2_ON			=>
						flashConfigWritedata<="11111111100111111111111111111111"; --Erase Sector ID1 (UFM1)
						stateErase<=ERASE_ERASECFM2_OFF;
					else
						stateErase<=ERASE_READSTATUS_B_ON;	--busy, testing again
					end if;
				when ERASE_ERASECFM2_OFF		=>
					stateErase<=ERASE_READSTATUS_C_ON;
				when ERASE_READSTATUS_C_ON		=>
					stateErase<=ERASE_READSTATUS_C_OFF;
				when ERASE_READSTATUS_C_OFF	=>
					stateErase<=ERASE_READSTATUS_C_VALUE;
				when ERASE_READSTATUS_C_VALUE	=>
					stateErase<=ERASE_ERASECFM1_ON;
				when ERASE_ERASECFM1_ON			=>
						flashConfigWritedata<="11111111101011111111111111111111"; --Erase Sector ID2 (UFM0)
						stateErase<=ERASE_ERASECFM1_OFF;
					else
						stateErase<=ERASE_READSTATUS_C_ON;	--busy, testing again
					end if;
				when ERASE_ERASECFM1_OFF		=>
					stateErase<=ERASE_READSTATUS_D_ON;
				when ERASE_READSTATUS_D_ON		=>
					stateErase<=ERASE_READSTATUS_D_OFF;
				when ERASE_READSTATUS_D_OFF	=>
					stateErase<=ERASE_READSTATUS_D_VALUE;
				when ERASE_READSTATUS_D_VALUE	=>
					stateErase<=ERASE_ENABLEWP_ON;
				when ERASE_ENABLEWP_ON			=>
						flashConfigWritedata<="11111111111111111111111111111111"; --Enable write protected mode Sector ID2, ID1 (UFM1, UFM0)
						stateErase<=ERASE_ENABLEWP_OFF;
					else
						stateErase<=ERASE_READSTATUS_D_ON;	--busy, testing again
					end if;
				when ERASE_ENABLEWP_OFF			=>
					stateErase<=ERASE_READSTATUS_E_ON;
				when ERASE_READSTATUS_E_ON		=>
					stateErase<=ERASE_READSTATUS_E_OFF;
				when ERASE_READSTATUS_E_OFF	=>
					stateErase<=ERASE_READSTATUS_E_VALUE;
				when ERASE_READSTATUS_E_VALUE	=>
					stateErase<=ERASE_FINISH;
				when ERASE_FINISH					=>
						stateErase<=ERASE_STANDBY;
					else
						stateErase<=ERASE_READSTATUS_E_ON;	--busy, testing again
					end if;
				when ERASE_STANDBY				=>
					if (actionErase='1') then
						actionErase<='0';
					else
						flashStatus<= (others=>'0');
					end if;
			end case;
		end if;
	end process erase_state;
I send IP setting and Scope signals (Read and Write signals are avmm_csr_read and avmm_csr_write, next signals are Core Status Register from flashStatus on my code).
Thank you, Tomas
  • TKapi's avatar
    TKapi
    Dear,
    thank you for your answer. Figure 11 and 12 is Read Operation. It working good [when I use "non-default initialization file" on "On-Chip Flash IntelFPGA IP", the data stored via USB Blaster I read via "On-Chip Flash IntelFPGA IP (figure 11 and 12 on your answer)" good].
    I can't erasing. I can't find any erasing figure or example, only 4.2.4. and 4.2.5. on your document.
    When i disable the write protection, then test BUSY state (=IDLE). Then I write erase operation in the status register. Then test BUSY state. BUSY state is BUSY_ERASE now, but only one clock period. Next clock period is BUSY reading IDLE again. Flash is no erased and es (erase successful) is 1'b0 always.
    I don't know what I doing wrong..
    Thank you, Tomas
  • TKapi's avatar
    TKapi
    SOLVED,
    my bad sequence:
    flashConfigWritedata<="11111111100111111111111111111111"; --Erase Sector ID1 (UFM1) *write protected is enabled again - bad!!
    flashConfigWritedata<="11111111101011111111111111111111"; --Erase Sector ID2 (UFM0) *write protected is enabled again - bad!!
    good sequence:
    flashConfigWritedata<="11111110000111111111111111111111"; --Erase Sector ID1 (UFM1) *write protected is disabled permanently- good!!
    flashConfigWritedata<="11111110001011111111111111111111"; --Erase Sector ID2 (UFM0) *write protected is disabled permanently- good!!
    Tomas
