MAX 10 Erasing via On-Chip Flash Intel FPGA IP - SOLVED
SOLVED,
my bad sequence:
flashConfigWritedata<="11111110011111111111111111111111"; --Disable write protected mode Sector ID1, ID2
flashConfigWritedata<="11111111100111111111111111111111"; --Erase Sector ID1 (UFM1) *write protected is enabled again - bad!!
flashConfigWritedata<="11111111101011111111111111111111"; --Erase Sector ID2 (UFM0) *write protected is enabled again - bad!!
flashConfigWritedata<="11111111111111111111111111111111"; --Enable write protected mode Sector ID2, ID1 (UFM1, UFM0)
good sequence:
flashConfigWritedata<="11111110000111111111111111111111"; --Erase Sector ID1 (UFM1) *write protected is disabled permanently- good!!
flashConfigWritedata<="11111110001011111111111111111111"; --Erase Sector ID2 (UFM0) *write protected is disabled permanently- good!!
Tomas
