TKapi
7 years agoMAX 10 Erasing via On-Chip Flash Intel FPGA IP - SOLVED
Dear friends, I'm using MAX10 (10M08DAF484C8GES), Quartus 18.1 and On-Chip Flash Intel FPGA IP. My problem is: When I need erase Sector ID1 or ID2 (or another), the "busy" from Core status Regist...
TKapi
7 years agoDear,
thank you for your answer. Figure 11 and 12 is Read Operation. It working good [when I use "non-default initialization file" on "On-Chip Flash IntelFPGA IP", the data stored via USB Blaster I read via "On-Chip Flash IntelFPGA IP (figure 11 and 12 on your answer)" good].
I can't erasing. I can't find any erasing figure or example, only 4.2.4. and 4.2.5. on your document.
When i disable the write protection, then test BUSY state (=IDLE). Then I write erase operation in the status register. Then test BUSY state. BUSY state is BUSY_ERASE now, but only one clock period. Next clock period is BUSY reading IDLE again. Flash is no erased and es (erase successful) is 1'b0 always.
I don't know what I doing wrong..
Thank you, Tomas
