PVanL's avatar
PVanL
6 years ago
making use of PCI Express Cyclone10GX Example Avalon-ST interface
Dear Intel Support,
I built the example as in ug-dex-a10-pcie-avst.pdf, using modelsim as simulator. It works as described. I want to use the PCIexpress by connecting the Avalon-ST interface to Intel's MAC (from the Low Latency MAC example), and my own PHY, see the attached powerpoint.
The point is, i cannot find any data moving on any line, except for the signals on the ST-interface, and on the serial data lines, but no data on any signal like e.g. "pipe_sim_only_xx" or whatever signal. So, i have no clue where to connect what signal, and /or how to pack ethernet signals as payload into a PCIexpress signal.
I am looking for an identifiable testbench in e.g pcie_example_design_tb, but cannot find it, also not in DUT_pcie_tb_ip, of which i expect it works as the testbench. Normally a testbench has a driver, a monitor, a comparator, some clocks and resets, and some wait statements to have the configuration settle down. I cannot find anything like that.
And do you have something that takes care in simulation to pack/ unpack ethernet into/from PCIexpress?
Thanks in advance,
Pieter
  • PVanL's avatar
    PVanL
    I did not look carefully enough. There are more ports and wires with active signals.
    The signals in the wave.txt are active during simulation, yet i find it difficult to identify what the meaning is of some of them, and where to intercept for the intended application, see above
  • PVanL's avatar
    PVanL
    Hi
