16 years agoLVDS and PLL IP on DE1
Hello, I am trying to implement a LVDS to RGB converter in the DE1 board. I am using the LVDS and PLL IP Megafunction. I used as a template the "Design Example 2: Cyclone II ALTLVDS Using Ext...
16 years agoFor now I am only interested in development board but if I will design my own one later, I will keep that in mind.
Also this is a bit off topic but basically if I want to use the LVDS protocol with a development board, I have to make sure that the board has adjustable Input Signal Levels, right? rbugalho said that it should be connected to 2.5 VCCIO. But I read that the maximum input voltage of LVDS is 2.4 V. So for example with 1.8 VCCIO, will it work? Thank you Meach
