16 years agoLVDS and PLL IP on DE1
Hello, I am trying to implement a LVDS to RGB converter in the DE1 board. I am using the LVDS and PLL IP Megafunction. I used as a template the "Design Example 2: Cyclone II ALTLVDS Using Ext...
16 years agoSo like rbugalho wrote: no LVDS for DE1. Too bad.
But if you ever gonna design your own board, make sure your LVDS-clocks are connected to a pinpair labeled "LVDSCLK" in http://www.altera.com/literature/dp/cyclone2/ep2c20_ep2c15a_ep2c20a.pdf. And make sure the external termination is right (I used 100 Ohm with success). Good luck, Ton
