JESD204B on Cyclone V SE
Is it possible to use the JESD204B IP on a Cyclone V SE device (as it doesn't have a transceiver block)? Can one of the supported I/O standards be used in place of GXB_Tx pins?
Hi Peter
Cyclone V SE device doesn't support JESD204B.
JESD204B is an interface protocol that required transceiver channels, it won't works if the selected FPGA doesn't have transceiver channels.
For Cyclone V family, need to choose GX or GT device to support JESD204B up to 5000 Mbps.
- skbeh
Contributor
Hi Peter
- PeterTs
Thanks for your response - that makes sense.
In that case I assume the SX device will also support JESD204B, as it has contains at least 6 high speed transceiver channels?
We need the SoC and DSP capability as well as the transceivers.
Peter
- skbeh
Contributor
Yes, Cyclone V SX device will also support JESD204B.
