L982123's avatar
L982123
7 years ago
Issues with SDI Audio Embed IP
I am evaluating the SDI IP and I have a couple of issues regarding the use of the Audio Embed IP.
  1. It is not possible to embed group 2, 3 or 4 independently unless group 1 is enabled first. This behaviour is only seen on HD/3G. SD seems to allow this.
  2. I have generated the core to include 24-bit support for SD-SDI and have set the register bits to embed the extended data packets yet I do not see 24-bit audio on the SDI output. I only ever get 20-bit audio.
Any suggestions?
  • CheepinC_altera's avatar
    CheepinC_altera
    Regarding the observation group 1 is required to be enabled so that other group can work, for your information, this is a known issue with the SDI Audio Embed IP. As a workaround, you would need to enable the group 1 first. Sorry for the inconvenience.
    • L982123's avatar
      L982123
      Is this something that will be fixed?
    CheepinC_altera
    Regarding the 20 bit audio observation, would you mind to further elaborate on the observation? Probably some simulation in Modelsim will be helpful for further understanding. Thank you.
    CheepinC_altera
    By the way, just would like to check with you which Quartus version are you observing this issue? As I check in the KDB database, this issue seems to be observed previously in Q17.0. I understand that Engineering will be fixing it in the future Quartus release.
    As I understand it, the SDI Audio IP for Quartus 19.2 has been recently released. Would you mind to try with the 19.2 audio IP to see if similar issue still persist?
    Chee Pin
    • L982123's avatar
      L982123
      I am using Quartus 18.1 and a Cyclone V device, so I am unable to try with 19.2.
    CheepinC_altera
    Thanks for your update. I understand that you are using Qstd and CV devices. Thus, you are unable to upgrade to Q19.2Pro. As a workaround, you might need to always enable the Group 1 currently. Sorry for the inconvenience.
    Chee Pin
    • L982123's avatar
      L982123
      I've just noticed that Quartus V19 has been released, but along with that they have removed support for SDI IP for Cyclone V. Can I use SDI II IP with the SDI audio IP? What are my options?
      Luke
    CheepinC_altera
    Sorry for the delay. Regarding your latest inquiries, yes, you can use the SDI II IP with the SDI audio IP.
    Thank you.
  • L982123's avatar
    L982123
    I've been told we cannot use SDI II IP + Audio IP + Cyclone V. Is this true?
    CheepinC_altera
    Sorry as I am not aware of the specific restriction. For your information, I have recently tested running SDI II IP with Audio IP in Q17.0Std and things seems to be working as expected.
    Probably you can help to refer me to the specific link which is related to the restriction that you mentioned so that I could further follow up from there. Thank you.
    CheepinC_altera
    Just would like to follow up with you on this. Please let me know if there is any concern. Thank you.
    Chee Pin
