L982123
7 years agoIssues with SDI Audio Embed IP
I am evaluating the SDI IP and I have a couple of issues regarding the use of the Audio Embed IP. It is not possible to embed group 2, 3 or 4 independently unless group 1 is enabled first. This ...
CheepinC_altera
6 years agoHi,
Sorry as I am not aware of the specific restriction. For your information, I have recently tested running SDI II IP with Audio IP in Q17.0Std and things seems to be working as expected.
Probably you can help to refer me to the specific link which is related to the restriction that you mentioned so that I could further follow up from there. Thank you.
