L982123
7 years agoIssues with SDI Audio Embed IP
I am evaluating the SDI IP and I have a couple of issues regarding the use of the Audio Embed IP. It is not possible to embed group 2, 3 or 4 independently unless group 1 is enabled first. This ...
CheepinC_altera
7 years agoHi,
Regarding the observation group 1 is required to be enabled so that other group can work, for your information, this is a known issue with the SDI Audio Embed IP. As a workaround, you would need to enable the group 1 first. Sorry for the inconvenience.
- L9821237 years ago
Is this something that will be fixed?
