L982123
7 years agoIssues with SDI Audio Embed IP
I am evaluating the SDI IP and I have a couple of issues regarding the use of the Audio Embed IP. It is not possible to embed group 2, 3 or 4 independently unless group 1 is enabled first. This ...
CheepinC_altera
7 years agoHi,
By the way, just would like to check with you which Quartus version are you observing this issue? As I check in the KDB database, this issue seems to be observed previously in Q17.0. I understand that Engineering will be fixing it in the future Quartus release.
As I understand it, the SDI Audio IP for Quartus 19.2 has been recently released. Would you mind to try with the 19.2 audio IP to see if similar issue still persist?
Chee Pin
- L9821237 years ago
I am using Quartus 18.1 and a Cyclone V device, so I am unable to try with 19.2.
