8 years agoIssue with 245 Fifo sync mode
Dear All, I am actually working on a communication chain between a FPGA and a FT2232H chip. So, the goal is to send a file from PC to FPGA, store it in a FIFO memory and then receive the se...
8 years agoDo you monitor RXF on falling edge of clock?
See http://electro-logic.blogspot.it/2014/03/fpga-comunicazione-ad-alta-velocita_1.html And let us know --- Quote Start --- Dear All, I am actually working on a communication chain between a FPGA and a FT2232H chip. So, the goal is to send a file from PC to FPGA, store it in a FIFO memory and then receive the sent data to PC. I am using the 245 fifo sync mode. All is working fine, expect that I rarely have a lose of one byte that appears randomly. So for example, when I send a packet of 512byte, i received well the 512byte but when I repeat this operations 200 times, I noticed that sometimes I only receive 511 byte and when I check where happens the lost byte, it happens randomly. And when I send a packet of 65.536 byte, again sometimes, I only received 65 535 byte. The strange thing is that when a lose occurs, this is always one byte. Can anyone help out me there to solve this problem ? Attached you will find my VHDL code. Thank you for your help ! --- Quote End ---
