- Somashekhar
Hi Team,
I want the Power output / power distribution value of Part number AGIB027R29A1E2VR3. This is required for Thermal simulation. We have input is 140W. It is an urgent requirement. Please reply as early as possible.
Thank you,
Somashekar
- HubertG
Contributor
That's Great !
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- HubertG
Contributor
Hi pudding_art,
A mail containing the "quartus.ini" file has been sent to your mail. Kindly check for receipt
- pudding_art
I've got it, thank you.
- HubertG
Contributor
Dear pudding_art,
Thank you for your patience. After checking from the backend, we noticed that -VR3 is an ES version (Engineering Sample) and had been discontinued its support and hidden since Quartus Prime Pro 23.4 Edition. Below is some workaround & advice for your reference:
- You may use Quartus Prime Pro 23.3 Edition to find -VR3 device, it is available in the device list. (Production version)
- If you insist to use the latest version of Quartus Prime Pro 24.2 Edition (beyond 23.3 edition), kindly reach out to your local distributor to get special INI file in order to access to particular device
- For -VRC, -VR3 or -1VB share the same pinout but the difference is they are for different power solution.
However, seems I am working with your case, I can try to help you to get the encrypted INI file. Kindly check your private mail within these 2 days, and reply with us upon received
Hope these information able to solve your problem. Feel free to let us know if you need further help on this.
Hubert
- pudding_art
Thank you very much.
- HubertG
Contributor
Hi pudding_art,
let me check with the relevant team on this issue and get back the workaround to you asap
Hubert
