16 years agoimporting hex files
Can I import hex files from quartus project with HDL import block?
As far as I know, the only option to import hex files is for ROM/RAM initialization.
Can you explain more. I'm a beginner with dsp builder
For what do you want the .hex files ?
Is it a processor executable ? FPGA bitstream ? RAM initialization ? ROM initialization ? State machine encoding ? - Altera_Forum
One more question: by hex, do you mean a file in Intel HEX format or just a text file with hexadecimal data?
Hi everyone,
I have a quartus project including fft megacore and some other vhdl files. I want to import all the project to simulink; when I do this with HDL Import bloc, I got many warnings like this one: Could not find RAM initialization file 'fft_opt_twr1.hex' What can I do to avoid these warnings - Altera_Forum
Put the .hex files in the same directory as the other files.
Or simply correct the path so that it points to the correct place. - Altera_Forum
Problem solved.:)
Thank you
