17 years agoHow to use altfp_sqrt with the Nios II?
Hi, for the reason of data processing I need the NiosII to calculate a floating point square root many times. The calculation without extra hardware block is to slow to meet the timing requirement...
16 years agothe higher pipeline should achieve a higher fmax but may use more logic/registers
