JET60200
Contributor
5 years agoHow to stop or cancel an “Read/Write AVMM DMA operation” after it begins ?
Hi Intel experts,
Sometimes I saw Arria10 " PCIe AVMM DMA operation” would consume much more time than it's expected. Such as in normal case, the DMA operation will consume around “+35us” to co...
JET60200
Contributor
5 years ago" One possible solution is to generate the Secondary Bus Reset from the host. It is available at the Bridge Control register Bit 6. "
-> Hello @SengKok_L_Intel ,
Sorry for the delay , but which document describes the mentioned " Bridge Control Register " ?
Pls help to point it out, so i could check it detailedly. thanks
SengKok_L_Intel
5 years agoYou can search the "secondary bus reset" or "bridge control register" from the PCIe spec.
- JET602005 years ago
Contributor
Thanks @SengKok_L_Intel for quick feedback,
I have no more questions on this ticket, thanks for kindly support!
