16 years agohow to set multiple ddr_hp_controller pin-name prefixes in one project?
:confused: Hi, I need help in compiling a stritixIII project with 2 identical ddr_hp_controller v.9 instantiation. In my design, a Megawizard generated ddr_hp_controller v.9 is instantiated ...
16 years agoJake,
I did what you suggested. Run two xxx_pinassignment.tcl files in separate times. The compilation was through but I still got only one set of ddr port name shown in that xxx_phy_autodetectedpins.tcl. It seems that no matter using default xxx_pinassignment.tcl without any user prefix assignment or using two separate pinassignment.tcl with user prefix assignments, the compilation results are same. :confused: Liza_altera
