16 years agohow to set multiple ddr_hp_controller pin-name prefixes in one project?
:confused: Hi, I need help in compiling a stritixIII project with 2 identical ddr_hp_controller v.9 instantiation. In my design, a Megawizard generated ddr_hp_controller v.9 is instantiated ...
16 years agoThank you Jakeobjones!:)
I will try the experiment you suggested. Is it weird if one have to open-close the Quartus to do the trick? I will let you know the result.
