16 years agohow to set multiple ddr_hp_controller pin-name prefixes in one project?
:confused: Hi, I need help in compiling a stritixIII project with 2 identical ddr_hp_controller v.9 instantiation. In my design, a Megawizard generated ddr_hp_controller v.9 is instantiated ...
16 years agoIn the assignment editor do you have assignments for both interfaces? If so then it worked.
From the compilation report you should be able to see if 2 controllers have been instantiated as well.
