16 years agohow to set multiple ddr_hp_controller pin-name prefixes in one project?
:confused: Hi, I need help in compiling a stritixIII project with 2 identical ddr_hp_controller v.9 instantiation. In my design, a Megawizard generated ddr_hp_controller v.9 is instantiated ...
16 years agoDont edit anything. The original tcl script is smart enough to work out you have two interfaces and it will set all the correct assignments for both.
You may have to start again if you have altered this file.
