16 years agohow to set multiple ddr_hp_controller pin-name prefixes in one project?
:confused: Hi, I need help in compiling a stritixIII project with 2 identical ddr_hp_controller v.9 instantiation. In my design, a Megawizard generated ddr_hp_controller v.9 is instantiated ...
16 years agoI believe the tcl file should be able to work out you have 2 interfaces and apply assignments for both, you dont need to edit it. Did you try just running it?
What version of Quartus are you using?
