How to set descriptor length dynamically in PCIe Hard IP (AVMM-DMA interface)
- 5 years ago
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
Hi Vicky,
Upon checking, you may use RD_DMA_LAST_PTR (Read) or WR_DMA_LAST_PTR (Write) to control the descriptor length. If 128 descriptors are specified and all of them execute, then descriptor ID 127 is written to the RD_DMA_LAST_PTR or WR_DMA_LAST_PTR register to start the DMA.
For example, if RD_DMA_LAST_PTR reads 4, the last descriptor requested is 4. To specify 5 more descriptors, software should write a 9 into the RD_DMA_LAST_PTR register. The DMA executes 5 more descriptors. To have the read DMA record the done bit of every descriptor, program this register to transfer one descriptor at a time. RD_TABLE_SIZE specifies the size of the Read descriptor table. The descriptor ID loops back to 0 after reaching RD_TABLE_SIZE. For example, if the RD_DMA_LAST_PTR value read is 126 and you want to execute three more descriptors, software must write 127, and then 1 into the RD_DMA_LAST_PTR register
You may refer to Intel® Arria® 10 or Intel® Cyclone® 10 GX Avalon® Memory Mapped (AvalonMM) DMA Interface for PCI Express* Solutions User Guide for details.
https://www.intel.cn/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_avmm_dma.pdf
KhaiY
- rMa15 years ago
Hi KhaiChein,
Do you mean RD_TABLE_SIZE could be programed at any time? For example, if I want to use descriptor length is 128, set RD_TABLE_SIZE=128 and RD_DMA_LAST_PTR=127(same as WR_DMA_PTR); then I want to use descriptor length is 15 after descriptor ID loop back to 0, I will set RD_TABLE_SIZE=15 and RD_DMA_LAST_PTR=14, is it right?
I want to know if descriptor table length could specific dynamically, in the manual, RD_TABLE_SIZE could be set (only) one time, should be set the maximum size, all descriptor ID need to go through until RD_TABLE_SIZE, although some times actually use descriptor length are less than RD_TABLE_SIZE(set by before), I mean it is no need to go though all descriptor ID if we could set RD_TABLE_SIZE any time.
Please correct me.
Vicky
