How to handle properly pfl_flash_access_granted & pfl_flash_access_request signals ?
I would recommend that you connect the nConfig to weak-pull high before we proceed as this will help on avoiding the device from getting reset.
Hi @JohnT_Intel
I raised this concern about the pull-up resistor to the FPGA_nconfig line.
However, my colleague came back to tell me that there was a hardware mod on the board adding a pull-up resistor to the FPGA_nconfig line.
I would not have been able to spot that that pull-up resistor modification was connected to the FPGA_nconfig line. My board has a DALE 1441 type (questioned to whether this a 1.44Kohm resistor? or 1441 means something else?)
Instructions they listed specified a 10K pull-up resistor and a 10K is the recommended value your link doc (listed within this ticket) suggested
Does it make a difference to the value of the pull-up? The larger the value the weaker it is. Isn't this the case? or should I attempt to change this to a 10k value one?
You suggested connecting the nConfig to a weak-pull high as this will help on avoiding the device from getting reset. The 1.44K resistor is a stronger pull-up. Will this be the reason of the issue seen ? Do I need to change it to a 10K one (ie weaker pull-up) ?
- Knug5 years ago
Contributor
Another meeting I had, my colleague confirmed that the DALE 1441 resistor (same one on his board) is a 10K one. When he unsoldered the resistor on one end he measured it as 10K and he said it was written 10K at the bottom of the resistor which I could not see whilst the resistor is soldered on the board. So FPGA_nconfig looks to have a 10K pull up resistor to 3V3
What is the problem then?? Why the FPGA cannot be configured? What causes the FPGA_nconfig stay low?
