How to generate .sof file for IP evaluation in tethered mode
I'm using Intel Quartus Prime Lite 18.0.0 with the
"Intel Cyclone 10 LP FPGA Triple-Speed Ethernet and Intel On-Board PHY Chip Reference Design"
When compiling the design I get the following error:
"Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
Warning (115005): Unlicensed IP: "Triple-Speed Ethernet(6AF7 00BD)"..."
How can I generate a .sof file to test the design in tethered mode using
Quartus Prime Lite 18.0.0?
- AnandRaj_S_Intel
Hi @HTork ,
To enable Intel FPGA IP Evaluation Mode.
During Intel® FPGA IP Evaluation Mode, the Compiler only generates a time-limited device programming file (<project name> _time_limited.sof) that expires at the time limit.
- In the Intel Quartus Prime software, click Assignments > Settings > Compilation Process Settings.
- Click the More Settings button.
- For Intel® FPGA IP Evaluation Mode , select enable.
Refer
https://www.intel.com/content/www/us/en/programmable/documentation/akc1496248329442.html#wwy1496248963591
Anand
- HTork
Yes, the Intel FPGA IP Evluation Mode is allready Enabled.
I tried to disable it an then enable it again pefore compiling, but I still get the same warning about the programming file.
Hans
- AnandRaj_S_Intel
The problem is "Triple-Speed Ethernet" does not support the Intel FPGA IP Evaluation Mode feature.
We Can't generate programming files because we do not have a valid license for the following IP core or cores.
I have used example from below link & Quartus 18.0. which does not generates programming file with below warnings
Warning (12189): Intel FPGA IP Evaluation Mode (Simulation-Only) feature is turned on for all cores in the design
Warning (12191): Some cores in this design do not support the Intel FPGA IP Evaluation Mode feature
Warning (12192): "Triple-Speed Ethernet" does not support the Intel FPGA IP Evaluation Mode feature
https://fpgacloud.intel.com/devstore/platform/18.0.0/Standard/intel-cyclone-10-lp-fpga-triple-speed-ethernet-and-intel-on-board-phy-chip-reference-design/
Kindly check the warning from Quartus message log.
Refer
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/megacore-ip.html
Anand
- HTork
Triple speed ethernet is opencore IP.
Note that I'm using Intel Quartus Prime Lite 18.0.0.
Some help would be greatly appreciated:-)
- HTork
I now see that I get all the warnings that you list:
I's nor clear to me how I can obtain a license for this IP so I can compile the design and make changes to it.
Could you please explain in some detail how you do that.
Kind regards,
Hans
- AnandRaj_S_Intel
Sorry for late reply.
You must obtain a license for the Intel FPGA IP to generate programming files that you may use for an unlimited time. To obtain a license file, visit the Self-Service Licensing Center or contact your local Intel FPGA representative.
Contact your local sales or distributor for more details.
Anand
