How to generate .sof file for IP evaluation in tethered mode
Hi @HTork ,
To enable Intel FPGA IP Evaluation Mode.
During Intel® FPGA IP Evaluation Mode, the Compiler only generates a time-limited device programming file (<project name> _time_limited.sof) that expires at the time limit.
- In the Intel Quartus Prime software, click Assignments > Settings > Compilation Process Settings.
- Click the More Settings button.
- For Intel® FPGA IP Evaluation Mode , select enable.
Refer
https://www.intel.com/content/www/us/en/programmable/documentation/akc1496248329442.html#wwy1496248963591
Anand
Yes, the Intel FPGA IP Evluation Mode is allready Enabled.
I tried to disable it an then enable it again pefore compiling, but I still get the same warning about the programming file.
Hans
- AnandRaj_S_Intel7 years ago
The problem is "Triple-Speed Ethernet" does not support the Intel FPGA IP Evaluation Mode feature.
We Can't generate programming files because we do not have a valid license for the following IP core or cores.
I have used example from below link & Quartus 18.0. which does not generates programming file with below warnings
Warning (12189): Intel FPGA IP Evaluation Mode (Simulation-Only) feature is turned on for all cores in the design
Warning (12191): Some cores in this design do not support the Intel FPGA IP Evaluation Mode feature
Warning (12192): "Triple-Speed Ethernet" does not support the Intel FPGA IP Evaluation Mode feature
Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
https://fpgacloud.intel.com/devstore/platform/18.0.0/Standard/intel-cyclone-10-lp-fpga-triple-speed-ethernet-and-intel-on-board-phy-chip-reference-design/
Kindly check the warning from Quartus message log.
Refer
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/megacore-ip.html
Anand
