How to generate .sof file for IP evaluation in tethered mode
I now see that I get all the warnings that you list:
Warning (12189): Intel FPGA IP Evaluation Mode (Simulation-Only) feature is turned on for all cores in the design
Warning (12191): Some cores in this design do not support the Intel FPGA IP Evaluation Mode feature
Warning (12192): "Triple-Speed Ethernet" does not support the Intel FPGA IP Evaluation Mode feature
Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
I's nor clear to me how I can obtain a license for this IP so I can compile the design and make changes to it.
Could you please explain in some detail how you do that.
Kind regards,
Hans
Sorry for late reply.
You must obtain a license for the Intel FPGA IP to generate programming files that you may use for an unlimited time. To obtain a license file, visit the Self-Service Licensing Center or contact your local Intel FPGA representative.
Contact your local sales or distributor for more details.
Anand
