16 years agoHow to generate MegaFunctions using TCL
Can I generate Altera Mega-functions ( external memory) using TCL. If yes Can you provide me the details(Docs or links)
16 years agoYou can run the Mega Wizard from the command line using the "qmegawiz" command. See chapter 2 of the quartus handbook (http://www.altera.com/literature/hb/qts/qts_qii52002.pdf) for details of using qmegawiz from the command line.
From TCL, you can use the "qexec" command to execute command line programs such as "qmegawiz".
