16 years agoHow to do frame rate conversion?
Hi, I'm trying to find an example on how to accomplish frame rate conversion with VIP cores. Does anyone have such example? For example, what would be the correct way of doing a simple scaling ...
16 years agoWhat you are doing is not actually frame rate conversion. You are doing a downconversion but your frame rates are the same. What are the physical interfaces for your video (SDI, HDMI, etc.)
Are you aware that Altera has a UDX reference design? http://www.altera.com/support/refdesigns/sys-sol/broadcast/ref-format-conversion-udx3.html Jake
