16 years agoHOW to convert serial RGB to parallel .i am using the ip\LCD_Panel_TPO_TD043MTEA1
HOW to convert serial RGB to parallel ,i want to convert the cyclone III neek MP3 example to my DE2-70 board ,but i found that the IP‘s RGB output was not the parallel,how to con...
16 years agoI have forgotten that, the project is on DE0 board(EP3C16F484C6).
you may modify pin connects, mega functions' device family... May be you'd better re-create a project.
