16 years agoHOW to convert serial RGB to parallel .i am using the ip\LCD_Panel_TPO_TD043MTEA1
HOW to convert serial RGB to parallel ,i want to convert the cyclone III neek MP3 example to my DE2-70 board ,but i found that the IP‘s RGB output was not the parallel,how to con...
16 years agothanks for your reply,but i just used the university program ip or a hard module timing controller,so i hope you can give me an example project of using the *clocked_video_output*,thank you....friend...
