16 years agoHOW to convert serial RGB to parallel .i am using the ip\LCD_Panel_TPO_TD043MTEA1
HOW to convert serial RGB to parallel ,i want to convert the cyclone III neek MP3 example to my DE2-70 board ,but i found that the IP‘s RGB output was not the parallel,how to con...
16 years agooh, sorry~
I really have no idea with lcd_panel_tpo_td043mtea1 if you have to work with it. but the clocked_video_output is pretty good for driving vga or lcds with clocked pixel scanning interface, so if you are using such a lcd, you may try using it.
