16 years agoHOW to convert serial RGB to parallel .i am using the ip\LCD_Panel_TPO_TD043MTEA1
HOW to convert serial RGB to parallel ,i want to convert the cyclone III neek MP3 example to my DE2-70 board ,but i found that the IP‘s RGB output was not the parallel,how to con...
16 years agothank you,but i did not use the video_sync_generator ,just the ip of MP3 example,named lcd_panel_tpo_td043mtea1 .It drives the LTM—TRBD of DE2-70 board.but it use for the cyclone III DEVICE ,i want to modify it,but failed..
