16 years agoHow to Connect to SOPC Avalong Bus from outside of SOPC
I'm using the SDRAM with Nios and SOPC, but I also need to write to the SDRAM via logic that is outside the SOPC. How is this typically done? I'm assuming I would need to create a peripheral ...
16 years agoit should be a lot faster with on chip ram... Is this ram shared with something else?
