16 years agoHow to Connect to SOPC Avalong Bus from outside of SOPC
I'm using the SDRAM with Nios and SOPC, but I also need to write to the SDRAM via logic that is outside the SOPC. How is this typically done? I'm assuming I would need to create a peripheral ...
16 years agoThis has been discussed in detail on the forum. I can't find all the posts but here are a few to try:
http://www.alteraforum.com/forum/showthread.php?t=19366&referrerid=2226 http://www.alteraforum.com/forum/showthread.php?t=12689&referrerid=2226 Jake
