18 years agoHow Can I set up DMA operation with my own PC software application?
Hi All: I want to re-use the pcie_highperformancedesign example provided by the Arria GX Development Kit. Now I am confused with the PC software application altpcie_demo.exe. :confused: I a...
18 years agoWhat I found confusing in the 'PCI Express Compiler Users Guide' on pg 6-19 was the relation of the 5 step process to kick off the DMA and the Chaining DMA Descriptor Table. The 5 step process sounds like the implementation of the Simple DMA. If it is not, what do the terms PCI Express address (step 1) and master memory block (step 2) refer to?
Does master memory block refer to Chaining DMA Descriptor Table's offset in BAR2? A few other questions I had about the example are:- Are the Descriptor Tables supposed to be written into the shared memory assigned to BAR2?
- Figure 6-3 shows the descriptor tables in RC memory. If this is the case, how does the Arria access these data structures? Is the RC memory in Figure 6-3 an implicit shared memory block?
- pg 6-19 says 'The software application writes the descriptor header into the into the endpoint header descritor register'. Table 6-7 maps the descritor headers to endpoint addresses 0x00 thru 0x20. These memory spaces conflict with the 5 step process on pg 6-19 to kick of the DMA. It looks like I am confusing something here. Does anyone know?
