17 years agoHelp with altera FFT
hello;
what i want to do is to get spectrum of an sinusoidal signal using the altera fft core i have generated a v8 fft with the following setting: fft point : 64 (to start with) architecture : brust data width : 16 twidle width : 16 i am including the matlab files in the attachment .. the input is a 64 point 2`compliment form. in the compare.m file i am doing three fft,,2 matlab fft and 1 altera core fft what i cant figure out is why the magnitude of the second and the the third power spectrum has bigger amplitude than the first fft at the signal fundmental frequency ? and why are those two are not so clean like the first one ? please have a look .. thanks to anyone who replies.56 Replies
Thanks for the block diagram. Can you please tell me how to generate the numbers for the LUT?
if you have MATLAB you can type "help window" to get a listing of the window functions and learn their usage. for example:
my_window = hann(window_length); it doesn't look like Octave has hann, but you can see which windows are supported here: http://octave.sourceforge.net/doc/funref_signal.html i attached a 256-point Hann window coefficient list. - Altera_Forum
Did you try the vector wave form simulation or only the matlab simulation???????????
can someone tell me please what is that function :
??? Undefined command/function 'Sfftmodel'. Error in ==> create_fft_model at 45 [roc,ioc,eoc] = Sfftmodel(rin,iin,N,THROUGHPUT,ARCH,DATA_PREC,TWIDDLE_PREC,INVERSE); ??? that is the function that altera creat for the fft , but matlab dont know that function... - Altera_Forum
there is a dll and mex file in $QUARTUS_ROOTDIR\ip\altera\fft\lib which you'll need
