17 years agoHelp with altera FFT
hello; what i want to do is to get spectrum of an sinusoidal signal using the altera fft core i have generated a v8 fft with the following setting: fft point : 64 (to start with) archi...
17 years agoIf you don't window the data before the FFT you will have artifacts from the truncation at the end/beginning of the FFT. This would cause some of the change in magnitude that you are seeing. In addition, there will be a less defined spike at the frequency of interest.
