17 years agoHelp with altera FFT
hello; what i want to do is to get spectrum of an sinusoidal signal using the altera fft core i have generated a v8 fft with the following setting: fft point : 64 (to start with) archi...
17 years agoTo be of any help can you tell me about:
your sampling frequency (of sinusoid) your fft sampling frequency do you use real and imaginary fft inputs and real/imaginary fft outputs how then do you combine real and imaginary into one signal your DAC sampling frequency(and do you correct for sinc distortion, see a today's post on that) How do you visualise spectrum? is it commercial spectrum analyser and do you have positive negative sides of spectrum?
