17 years agoHelp with altera FFT
hello; what i want to do is to get spectrum of an sinusoidal signal using the altera fft core i have generated a v8 fft with the following setting: fft point : 64 (to start with) archi...
17 years agoNo, just for test purpose. It will just change the phase of audio signal which is irrelevant to hearing. For test it may improve on amp fluctuation resulting from phase change as explained above in that both channels contribute to final amp. This is trivial but worth trying it.
