18 years ago
GMII <-> MII bridge in MAX II CPLD ?
Hi Folks,
In my board, I would like to use GMII to MII bridge in MAX II CPLD. But I don't have idea of
> Whether it can be used in MAX II CPLD (LE utilization and device electrical characteristics support)?
> If it is possible, Then any vendor can provide the ip core of this bridge ?
> Do any one have design documents relating this or any suggestions from yours.
Vijayan
    What's the intended purpose of the design? GMII should be MII downward compatible by specification, normally no bridge would be necessary.
    Sorry, There is a correction. It is RGMII <-> GMII.
    And in the design, CPLD should make this bridge between the processor and the switch
    OK, RGMII to GMII....Please ignore this post!!!
    I don't see any reason why a GMII to MII interface could not be implemeneted in a MAX II part.
    The CPLD should be able to be clocked fast enough (MII runs at 25MHz, GMII runs at 125MHz for Gbit ot 25Mhz for 100M) I assume you will run the GMII side at 10/100M rates to remove the need for traffic shaping/buffering in the CPLD in the GMII to MII direction)
    The MZX II i/o should be suitable for both MII and GMII (Spec'ed as 3.3V LVTTL if memory serves)
    In terms of CPLD complexity, I expect that MAX II would be able to realize the interface. But RGMII is utilizing a DDR transmission (dual edge). MAXII unlike e.g. Cyclone FPGA has no dedicated DDR I/O circuit. So a combination of dual-edge synchronous and asynchronous logic must be used. I doubt, if the timing requirements can be met at 125 MHz with this technique.
    Thanks for all your response.
    Is there any other possible solutions we have...?
