16 years agoGigabit Ethernet, Cyclone III and RGMII
I want to interface a gigabit phy to a cycloneIII part using the RGMII as seems to be the case with the 120 Dev kit but upon looking under Switching Characteristics I see that C7 can do 237mhz out and C8 is only good for 225mhz. Toggle Rates seem to be defined as the number of 0->1 or 1->0 transitions per second which would seem to imply 1000mhz/4 pins in RGMII running at 250mhz. I guess the gist of the question is: in the switching characteristics is the toggle rate = (0->1 + 1->0) / sec or either (0->1)/sec or (1->0)/sec?
Probably even shorter question: will the EP3C25E144C8 drive a gigabit Phy using RGMII or is it necessary to use GMII? Thanks, Phil1 Reply
The RGMII interface is actually a DDR at 125 MHz. Altera's example design uses a C8, it compiles fine and passes the timing analysis, so there isn't any problem making it run.
