Gyud0
4 years agoGeneric serial Flash interface sector erase problem
Hey,
I'm using the Reference design Generic Serial Flash Interface IP on Quartus Prime 18.1 to access Micron MT25QL512Mb flash memory.
Via NIOS processor, I able to erase the memory sector 0 (at ...
hareesh
4 years agohi GAL YUD,
please check WRITE ENABLE command is executing or not before initiating ERASE command. in you shared code lines WRITE ENABLE command is not there.
thanks,
- Gyud04 years ago
I'm executing the write enable command before I initiating the erase command. It's the same order that I do successfully in erase sector 0, the only change is the desired address to be deleted
- hareesh4 years ago
check lock protection enable or disabled. before erase sectors needs to disable lock protection. pls check that.
