ADmcj's avatar
ADmcj
8 years ago
Functional test of the FFT IP
Hi all,
I would like to test the FFT IP.
As such I tried to use the example that is generated with the IP parameter editor (quartus 17.1), but it generates only stuff in verilog while I need vhdl. Moreover, everything is automated with a script (compilation) and as such I don't know how to organize the files in my own project in modelsim.
So my question is: after having generated the IP with quartus, what files are required to be imported in ModelSim in order to be able to launch a simulation of the block?
Thank you!
  • vj123's avatar
    vj123
    1. While Configuring parameters of FFT IP use "​Generate HDL.." tab & choose VHDL under Synthesis & Simulation.
    2. Check output Directory path.
    3. Then click on "Generate"
    4. Use that generated .vhd file under Synthesis Directory as a design under test(DUT) in ModelSim & write a test bench for simulation if you don`t want to simulate it using TCL script.
    5. If you want use Automated test bench then use NativeLink.
    Best Regards
    Vikas Jathar
  • ADmcj's avatar
    ADmcj
    Sadly is not working.
    I imported the file as you said and passed the input as specified in the manual, but the block doesn't do anything. Not even error on the error line.
    EDIT: I am using variable streaming with fixed point.
