ADmcj
8 years agoFunctional test of the FFT IP
Hi all, I would like to test the FFT IP. As such I tried to use the example that is generated with the IP parameter editor (quartus 17.1), but it generates only stuff in verilog while I need vhdl. ...
ADmcj
8 years agoSadly is not working.
I imported the file as you said and passed the input as specified in the manual, but the block doesn't do anything. Not even error on the error line.
EDIT: I am using variable streaming with fixed point.
